project nightmare
Old 09-15-2008, 06:28 AM
BIG_T's Avatar
Default project nightmare
OVERVIEW:
as some of u know at the end of july i was driving home from work and got rearended on 71 south. i was going 25mph in the slow lane with my hazards on bc i wanted to be cautious and this is what happened.......
So....i bought a buddy (skinnies) 1996 formula roller that came with q1a's and a wire tucked engine bay and some other goodies for 1700ish. then i sold my full suspension set up on off the camaro except for the spohn 1in rear sway.
GOALS:
make a fun weekend car that can compete for the bolt on m6 record (11.805@113.96) and run mid 11's on the bottle
parts from camaro (denzel) thats getting used: 80k lt1 w/ 1.6rr and manley springs, t56, moser 9in with spool, ls1 rear brakes, and 4:11's, draglites, Titainium Retainers, pro 5.o shifter, acpt carbon fiber driveshaft, and some others im forgetting
parts adding to the engine/chassis from the camaro:
kirkey pro street seats, elec. water pump, nano kit, front k-member/lower a arms, umi adj lca's and panhard, bmr extreme tq arm, pirate subframes, battery relocation, manual brakes, and a few other odd and ends.
race weight goal:
2850
9/2/2008
finally started tearing into my project last nite (been moving into a new place). worked about 2 hours and got alot done.
buddy took the front bumper stuff and fenders off of denzel
took the moser 9in out and got a closer look at the damage to the passenger side spring cup
went outside and worked on the formula (nightmare)
took out the carpet and seats since im saving for kirkey's and ozite carpet. took out all 4 rear speakers (not gonna run a cd player, making a custom gauge holder deal in the cd player hole), the auto stuff, and the ebrake assembly.
9/15
the camaro now has the tranny, all rear suspension, and dash all out. starting on the motor here in a few. i ordered UMI chromoly double adj lca and panhard bar last week.
picked up a ls1 slp lid setup and two 275/60/15's to put on my draglites from a local tonight along with the custom alternator bracket that levi made for his old 383 pro setup. thanks for the hook up's fella's
will be ordering the pa k member in a few days. still deciding if i should order it with the pinto setup to run a manual rack or not.
a local lsx guy is in the process making some nice custom seat brackets for the kirkleys i got to sit in a car tonight with the 17in seat for the driver side ill prolly order the same seat setup that he is rolling with (17in ds and 19in ps)
thats all i got done so far. ill get some recent pics up when my camera charges
Old 09-15-2008, 09:18 AM
camar0corey's Avatar
Nice! Glad things are working out, and sounds like most of the performance goodies survived the wreck.
Old 09-15-2008, 09:27 AM
AChotrod's Avatar
Looks like your moving along pretty fast. Lets see a few pics of the formula.
Old 09-15-2008, 09:59 AM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
2850 will be interesting, but it is doable. You're going to have to buy quite a bit of stuff to hit that kind of weight. I've got mine all calculated and figured it would be around 2917.740301 if I didn't add the turbo setup and did everything else I planned on doing. That's also with AC, PS, all the interior panels, 8 point cage, etc... Prepare for a lot of work either way. I have quite a few months in just taking the time to strip my 93 down.
Old 09-15-2008, 10:02 AM
James Montigny's Avatar
Old 09-15-2008, 11:15 AM
registered user
ScreaminRedZ's Avatar
Sucks about your old car, but it looks like you've got a solid project to start again! Good luck, keep us updated.
Old 09-15-2008, 06:32 PM
SoxXpupPeT's Avatar
wow man thats a helluva transition your going to be pulling. but you have plenty on your hands to keep you busy for awhile! best of luck and you better be updating this regularly!
Old 09-19-2008, 09:18 AM
BIG_T's Avatar
-here is pics of the formula
(thanks goes to my roomates dog for diggin a whole and throwing the dirt next to the car lol )
-interior shot of how it sits right now
yes this is a auto swap so m6 swap will be done with the help of a buddy.
-engine bay with all the nice work done by skinnies (reason i bought the roller)
current pics of the camaro...
-^tranny covered and sub that was in the camaro^
engine is ready to be pulled and will get yanked out today (couldnt find a chain last nite lol)
chromoly lca's and panhard...this things are light!
and of course the old acpt carbon fiber driveshaft off the camaro
thanks for looking guys im going to call pa racing right now
Old 09-19-2008, 09:46 AM
z28rob18's Avatar
thats an awesome project good luck wit that record keep us updated
Old 09-19-2008, 12:37 PM
hashtagBMW
Speed Density's Avatar
Your camaro got fucked hard, good luck with the project!
Old 09-19-2008, 12:57 PM
1SlowFormula's Avatar
BIG_T - It sounds like you have a fun project, I wish you the best on getting that bolt-on record, I have tried a few times this year and hope to do better when the weather cools off some more, plus I dropped about 240ish # off the car since the 11.86 I ran in the spring...
Beaflag VonRathburg - I need to weigh mine but after doing the front brakes and the latest rounds of weight reduction I think I may be somewhere near 2850# right now, we will find out when I take it to the track this Sunday and weigh it there...
Old 09-19-2008, 01:06 PM
z28rob18's Avatar
1slowformula if u ran 11.8 then ys ur title 12 second club not 11?
Old 09-19-2008, 01:24 PM
because the title settings were messed up last spring when I ran the 11 second run and there was a sticky stating this, but I just went to that section and found the stickies removed so I guess thay have that working again, so I will put my name on the list to get that changed, thanks for letting me know it was working again...
Old 09-19-2008, 08:50 PM
67goatman455's Avatar
sweet, ill keep watching. not sure if you do, but put it up on kcsr!
Old 09-20-2008, 02:53 AM
jarretthise's Avatar
looks like my project i took on....its almost done now...its not impossible man...good luck bro..it takes time but in the end it is worth it and you will have 10 times more pride in it than before...
Old 09-20-2008, 03:43 AM
BIG_T's Avatar
thanks for the kind words guys
tonight me and a buddy worked on the camaro for about 3 hours. cut the front core support out, pulled the motor, pulled engine/trans harness, pulled the whole pedal assembly, pulled slave cylinder and clutch master, took out the master and booster, started taking off the body harness, we took out the stock k member and front suspensuon. all thats left is finishing the body harness, line lock and brake lines then its going to the crusher
Old 09-20-2008, 03:45 AM
BIG_T's Avatar
ill be looking for ur threads when u break it. 240 off is a great chunk man good work i sent u a pm btw
Old 09-20-2008, 07:53 AM
are you saving every inch of this car?? just wondering
Old 09-20-2008, 10:01 AM
My PM box is full let me filter through some things to delete and I will send a response...
Old 09-20-2008, 12:06 PM
BIG_T's Avatar
i sold the front clip, core support, doors, ect ect i still have the full interior and dash ill sell from the camaro. im using alot off the camaro for the bird (motor, tranny, wiring, rear, and the aftermarket gauges)
Quick Reply: project nightmare
