wtf ?????HELP ASAP
wtf ?????HELP ASAP
after installing my pacesetter long tubes my steering linkage is hitting my headers why is that ?? the last long tubes i had on my car i didnt have this problem ANY IDEAS ???
no idea... i have pacesetters on mine and never had this issue... i say just check the way everythings welded together.... maybe your exhaust is offest to that side so much when it got welded together the header got pulled that way a lil bit... just an idea.
i second that the last thing you want to do is screw the sterring linkage up just to install headers. return them and tell them they dont fit maybe you got a bad set or the wrong year?
i havent taken any pictures yet but i will tomorrow when i get home from work my car is a 95 z28 camaro the headers i ordered were pacesetter lt ceramic coated
part number 72c2239
http://www.byunspeed.com/product_inf...40de17b8fd4c46
before i installed these i had pacesetter lt painted headers with emissions and i had absolutely no problems with those
part number 72c2239
ok will call them now because the linkage is just fine never been in a wreck i didnt bend it the other long tubes fit just fine thanks for all your help everyone
the painted long tubes did before but it melted off and fit fine its actually hitting the linkage itself rotating bar that connects to the rack and pinion and steering column
Yea, so basically the same headers. You could've just cut off the emissions provisions or welded a plate on it.
Example for 97-01 Vettes, other than the angle of them for picture, look at the difference.
"Race"
Emissions
Conlusion: There is no reason they should hit and you wasted some money
"Race"
Emissions
