suggestions please
suggestions please
im planning on buyin a nitrous system and would like some opinions here. my car and mods are in my sig. and im lookin to spray a 100 shot for now. wat brands u suggest and wet or dry. im lookin for a safer system i no its only unsafe wen the mixture leans out but i figured id still ask for safe. thanx for any help
There are alont of different brands and styles available. As far as wetvs dry I suggest doing some home work and determain what best fits your needs. Then decice what style and brand system will work for you.
Here is a great read to understand the difference between wet vs dry from a neutral standpoint.
http://www.nitroustech.com/forums/showthread.php?t=92
Here is a great read to understand what the accessories do that need to go along with the system.
http://www.nitroustech.com/forums/showthread.php?t=2
If I can answer any questions let me know.
Dave
Dave
You may want to look at the HSW dry setup, very easy to use and comes with the interface for tuning the AFR, if you ever wanted to go wet you would just buy a fuel solenoid and you'd be set and you could still use the interface for fine tuning. They also have a completion kit that will give you everything you would need. The window switch that comes with the kit is awesome!! It's a window switch, lean shutdown switch, multi gear lockout and more. They have some of the best cutomer service around!
I like wet kits. From my experience, nozzles don't hit as hard as plates. So, if you are spraying off the line with stock parts, the nozzle(s) could make that 10 bolt with 4.10's last a little longer.
If you want it to hit hard, I know it's a little dated but I had really good results with the Nitrous Works plate on my LT1
If on a budget our Brand X single nozzle systems are hard to beat. If you want the best of the best I would look into the Nitrous Outlet plate LT1 plate systems. The plate gives the best attomization with the LT1 intake and also makes for a super clean install. The entire system is designed to flow and take abuse. This system will produce over 400 Hp.
Dave
Dave
Yes sir..
This is the Nitrous Outlet plate system-
http://www.nitrousoutlet.com/catalog...roduct_id=2806
Brand X single nozzle-
http://www.nitrousoutlet.com/catalog...roduct_id=2891
Nitrous Outlet Plate conversion-
http://www.nitrousoutlet.com/catalog...roduct_id=2808
Brand X single stage window switch with built in TPS
http://www.nitrousoutlet.com/catalog...roduct_id=2885
If this fits you budget this is a good accessory package-
Brand accessory package- We sell these accessories individually as well.
http://www.nitrousoutlet.com/catalog...roduct_id=3241
Dave
Dave
