High oil pressure after TR220 cam install. Please help
Old 09-07-2003, 03:25 PM
TAhawk69's Avatar
Default High oil pressure after TR220 cam install. Please help
Just had a TR220 114lsa cam installed. At idle my oil pressure is about 55-60. Before the install it was always at 40 at idle. I adjusted the idle screw and enlarged the TB hole in the blade just a little. What is causing these high oil pressures, and is it something to be concerned with?
Thanks,
marco
Old 09-07-2003, 04:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
Default Re: High oil pressure after TR220 cam install. Please help
Did they do a oil change with thicker oil?
Quick Reply: High oil pressure after TR220 cam install. Please help
