Car sits to low
Car sits to low
I bought the car with qa1's up front and need to raise it up to help with the 408, I was told what I need is lt1 springs what are you all thinking Thanks Brandon
Yeah, thats all you need;One to hold the spring seat still, and the other to loosen/tighten the lower collar(jam nut).
FYI,
Spray some WD40, or dry lube on the threads right above the spring seats before trying to loosen them, and be prepared to lose some skin on your Knuckles in the process.
