1SlowFormula
09-17-2008, 06:46 AM
Hey all,
I finally got everything finished with the front-end and brake install, all my flare joints were good and bled the system, but noticed that my new Line Lock (LL) was seeping from between the 2 parts of the case.
When I first installed everything I had over tightened the fitting on the bottom and then turned it back slightly to match up to where the brake line was going, but noticed I turned the whole bottom part of the LL when I did that. I have since retightened the bottom part of the LL housing but there is still seeping from the area where the 2 parts com together.
The seeping does not appear to put air into the system, and doesn't change when there is presure in there or not, nor does it feel like pressure is bleeding off when I hold the brake pedal in firmly.
I have done some googling and it sounds like I should be OK with the way it is since there is no air getting in or pressure leakage (that I feel), and hell it would almost not even bother me, but it seeps and then finally after a few minutes (about 10) or so it forms a single drip that drips down onto my steering shaft and headers causing a bunch of smoke...
These things a rebuildable, should I take it fully apart and see what's going on or would that be a bad idea?
