verfiying correct injectors for my setup
http://www.byunspeed.com/product_inf...e1fd7db1a17d51
this is the style i need correct? and this should suffice for 420~ horsepower on motor at the wheels?
well first of all that link isn't working properly.
could you please just type what injectors they are and their ratings.
I'm guessing 42# injectors would suit you fine. Juicy juice being N20? wet or dry kit?
you want high impedance
they are 30lb ford injectors. And it's a wet kit so only motor numbers matter. I did a calculation and it looks as if 35 lbs will be 80 percent. The injetors looked like the fat Bosch ones not the skinny injector.
you might be better going with 42# injectors. you are stretching yourself a little on those 30's.
I've got lucas 42's in stock ready to ship for $290 out of the box, $330 for a flowmatched set.
-Adam
-Adam
