how difficult is it to install a torque arm?
Old 09-18-2008, 03:49 PM
redbadss's Avatar
Question how difficult is it to install a torque arm?
i was thinking about getting a torque arm for my car and was wondering how hard it is to install this and what will i have to remove to install it?
Old 09-18-2008, 03:56 PM
2QUIK4U's Avatar
Its really easy with the stock 10 bolt, but with my 9" and true duals run out the back it is a complete PITA. If I were you I would go with some other mods first.
Old 09-18-2008, 03:57 PM
AChotrod's Avatar
3 bolts and cut out the old bushing. Its easier than changing the oil.
Old 09-18-2008, 03:58 PM
redbadss's Avatar
i am saving to buy a group of suspension parts, and the torque arm is the most unfamiliar part i have looked at,
Old 09-18-2008, 04:00 PM
nemss1's Avatar
redbadss, where from OK are u?
Old 09-18-2008, 04:01 PM
redbadss's Avatar
up north in bartlesville..
Old 09-18-2008, 04:20 PM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, take a look at the video on our main page. It shows the install and correct way to set your pinion angle. If you have any questions please give me a call.
http://www.bmrfabrication.com/
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-18-2008, 06:32 PM
redbadss's Avatar
do i just take the car to a shop to get it up in the air like they have it? or can i just jack it in the air and do it that way, it seems like it would be very difficult to do it when the car is just jacked up...
Old 09-19-2008, 05:51 PM
JonCR96Z's Avatar
It shows the correct way, but gives the wrong value.
https://ls1tech.com/forums/suspension-brakes/974198-measuring-pinion-angle.html
Old 09-19-2008, 09:22 PM
Major_Lee_Slow's Avatar
I did it in my garage on jack stands. The hardest parts was getting the poly bushing back into the clam shell bracket on the trans and closing said bracket and starting the bolt. I finally had to get my wife to get under the car to help me cause my hands were just too damn big to get into the space.
Old 09-19-2008, 10:14 PM
redbadss's Avatar
alright thanks man, i was hoping i could use jacks to do this..
Old 09-19-2008, 10:16 PM
99FormulaM6's Avatar
it will be easier if you put jacks on the frame of the car and keep a jack under the pumpkin to raise/lower the rear while youre doing it. I had to raise/lower the rear a little a few times to make it slide on real easy.
I have a BMR Adj Tq Arm BTW..
Old 09-19-2008, 10:25 PM
redbadss's Avatar
alright thanks, did it help the traction and wheel hop on the car any after install? could you tell a difference?
Old 09-20-2008, 08:23 AM
I noticed an immediate improvement in straight line acceleration.
Old 09-20-2008, 10:33 AM
redbadss's Avatar
thats nice to hear, my car will be on the street most of the time so that's what i'm really looking for.
Old 09-23-2008, 01:34 PM
litle88's Avatar
LOL
+1 for the same scenario!
Try to jack it up as high and SAFE as possible and have some little hands available, it's really not that hard!
Also if your buying suspension parts make sure they are adjustable, like Panhard bar and torque arm cause if you lower your car you will need these things to have good alignment. Goood luck!
Old 09-23-2008, 02:01 PM
BMR Suspension's Avatar
Before you buy your torque arm, make sure that you investigate the design and manufacturing features of each torque arm. You will find that torque arms are NOT all the same. Each of the manufacturers build them differently, and some designs are superior than others. You want a stiff torque arm, not one that bends or flexes under extreme loads.
By the way, most of the 7-second and 8-second cars at the LSX ShootOut will be using off-the-shelf BMR Torque Arms.
Your car may never have 1000+ horsepower, but you still want a stiff torque arm for a good launch. Good Luck!
__________________
Allan Miller
President
BMR Suspension
www.bmrsuspension.com
(813) 986-9302
Old 09-23-2008, 09:51 PM
redbadss's Avatar
haha yea my car probably won't get any where near the 1xxx hp numbers but i will definately take in consideration the bmr torque arm, there are a lot of positive feedback on those torque arms.
Old 09-25-2008, 04:32 PM
BMR Tech2's Avatar
Thanks we try to make a quality product that works like we say it does. We offer a two year warranty to the original purchaser and some of our products have a lifetime warranty. Our tech dept is available till 6pm est mon-fri for tech help.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Quick Reply: how difficult is it to install a torque arm?
