Power to be gained and safety of setup????
Old 09-18-2008, 06:30 PM
jt76's Avatar
Default Power to be gained and safety of setup????
A local guy is trading me his NOS wet plate kit for my old rear end setup next week. I want to run a 100 shot on top of my current setup. I have:
231/237 112LSA cam
FAST 90/90
Lt headers/ORY/ catback
racetronix fuel pump
lid
M6
All i have to do is buy the 90mm plate. With my current setup i am making around 415 rwhp, what kind of HP and TQ can i expect on a 100 shot? I have heard of gaining more than 100 rwhp, which i would be afraid of because of my stock bottom end. What do you guys think about this?
Old 09-18-2008, 07:32 PM
BAKED's Avatar
Did you buy that white T/A in Kentucky?
Old 09-18-2008, 07:36 PM
jt76's Avatar
Mine is the Pewter one, and the white one is my friend, he bought it in Ohio i believe
Old 09-18-2008, 07:39 PM
Turbo LS1 SS's Avatar
i heard you will only make about 450rwhp or so
the white ta was bought in MS btw
Old 09-18-2008, 07:40 PM
jt76's Avatar
i could have swore pat got it in Ohio? must be someone else. You would know more than me
Old 09-18-2008, 07:42 PM
btw you should be safe, but you aren't exactly extending the life of things if ya know what i mean
Old 09-18-2008, 07:45 PM
BAKED's Avatar
Ahhh, I sold a 30th Ann. T/A for a friend of mine to a guy in New York, Just curious...
As far as your question.....With a safe tune up you will see somewhere arond 100 rwhp gain and over 100 rwtq since you have a M6. The lower the rpm's the more torque you will make. Just to be safe I would buy a window switch and set it to come on at 3K RPM's and go off at 6500 RPM's. A FPSS wouldn't be a bad idea either.
Just search around in here, there are hundreds of threads just like yours, you should be able to find answers to any questions you may have.
Old 09-19-2008, 01:37 AM
jt76's Avatar
As i mentioned, the kit has the stock size plate, and i have a FAST 90, will this plate work for me? i THINK LS2's are 90mm (?)
http://www.nitrousoutlet.com/catalog...roduct_id=1650
Old 09-19-2008, 02:35 PM
jt76's Avatar
anyone with input here?
Old 09-19-2008, 03:03 PM
8sec-z's Avatar
I don't know if LS2's are 90mm, but there have been a few used plates that are 90's lurking around the lsx for sale area.
I cut 8 tenths off my 1/4 mile time with a 100 wet shot two weeks ago and all I had was a catback. You should expect 100 rwhp and nearly 150 rwtq off a 100 shot, whether you run a M6 or A4. Torque should always be around 150% of the hp tuneup you install.
I can't wait to install my 3000rpm fuddle and go back to the track...
Have fun with it!
Old 09-19-2008, 03:07 PM
BAKED's Avatar
I have a good friend that has a 90mm plate for sale. PM me if you need one.
Old 09-19-2008, 03:26 PM
2QUIK4U's Avatar
I gained 145rwhp and 192ftlbs on a 100 shot with a similar setup.
