Wiring question (what 12v. power acc. do you use?)
Not the Battery 12v., but the Acc. 12v. on/off with switch, where do you run yours from? Do you go off the fuse panal or somewhere else? This will be for my Noids/Purge/Heater Acc. Heater & Noids will be run through relays.
