Stereo & Electronics - Ground location
mbrownin
09-19-2008, 01:05 PM
Updating my stereo system in my 2000 SS, with new speakers, sub, and 2 amps mounted on an amp rack in the back. Trying to determine the best location to ground the 2 amps, which will both have 8 ga. power wire off a distribution block being fed by a 4 ga. primary power source. Where did any of you guys connect the ground to?
94'BLKBRD
09-19-2008, 01:56 PM
Would like to know aswell.
cookba
09-19-2008, 02:09 PM
sand down a spot in the wheel well and bolt it on there with some dielectric grease.
pentavolvo
09-19-2008, 06:19 PM
anywhere in the wheel well area, or behind the carper on the rear wall
vjo90rs8
09-19-2008, 08:29 PM
I took removed the passenger side top seat belt bolt (you can see if once you remove the spare tire cover/trim), filed off a big section of paint, then sandwiched a spade connector between the bare metal and seat belt metal bracket, tightened the bolt down really tight, so far so good with my Kicker 480W monoblock amp. I do plan to upgrade to 4 gauge wire for the ground and will probably use the same location unless someone chimes in and says "you dumb ass, that is a terrible ground". Read other people using it in other posts. Figured its just as good as bolting to bare metal.
*98TransAm*
09-19-2008, 08:30 PM
yeah theres a few nuts/bolts in the rear fender well, just remove the nut or bolt, take a wire brush to the metal till paint is gone and ground off of that.
Snootch
09-24-2008, 02:51 PM
I found a nice thick chunk of metal under the rear passenger "armrest". Just remove the plastic, sand the paint down, and install like this:
http://snootch420.googlepages.com/ground.jpg/ground-full.jpg
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
