Is there any way to hide the n20 lines in a lt1?
i know on an ls1 they can be hid under the stock manifold and cant be notices..so i was wondering if there is any way of hiding n20 lines in an lt1?
heh I was going to say to put it under the elbow, instead of on top, and then I ran into Larry's pic! So, that answers THAT!
You can always paint stuff black, or even be more stealthy and run rubber hose OVER the metal line!
"What's that going to <object>?".
"Just <fuel/vacuum/other> lines."
I Have Seen Complete Fogger Systems Run Under The Manifold With 2 Lines Comming Out The Back Of The Manifold.but This Requires Extensive Fab And Money. The Solenoids Were Hidden Inside Of The Cowl. And The Lines Out Of The Manifold Look Like Vacuum Lines
Oh, sweet Angela! And quite the big sin you guys have committed for not only putting no links to larger pictures, but also not linking to ls1tech in your "Sites we sponsor"! [/hijack]
I've seen a posted picture on here once of the underside of the intake manifold setup as a direct port nitrous (I think) setup with the hookups poking through the back of the manifold. Pretty sick! Anyone know where that photo is???
