Not doing a relearn, will is cause crank sensor to go bad?
Old 09-20-2008, 04:26 PM
candlelit's Avatar
Default Not doing a relearn, will is cause crank sensor to go bad?
If I install a new crank sensor, and do not do a relearn, will I still have problems and will it cause the new sensor to go bad? Is it 12 or 14 ohms for the crank sensor? How can I get a pcm relearn done? I don't have a tuner/scanner and don't want to spend $200+ for one.
Old 09-20-2008, 04:39 PM
2xLS1's Avatar
Crank sensor relearn is primarily for accurate misfire detection. Stop worrying about it.
Old 09-20-2008, 05:04 PM
SLawson86's Avatar
my suggestion is find a buddy with a GM scantool (tech II) and do it. if you go to a dealer, they usually charge about an hour to do it. if you dont do a relearn, like 2xLS1 said, it willpick up random sporatic misfires and the SES will come on. or another suggestion, go to a dealer, find a tech walking around and offer like 25 bucks cash to do it on the side really quickly. trust me, it works. i take donations all the time
