Thinking of another 25 shot.......
Old 09-20-2008, 06:14 PM
BOLO's Avatar
Default Thinking of another 25 shot.......
If I bump it up to 175 shot, will I need another tune? a/f adjustment? pull more timing?
Am I pushin' it on the stockbottom?
Old 09-20-2008, 06:27 PM
daniel6718's Avatar
lt1 bottom end yes.....put a colder plug in there...and make sure your timing is low....dont get greedy...timing(detonation) and heat(ringlands) will be the 2 thigns that will make it let go...
if i was you id break it up some though...the TQ spike from that shot will also be another bottom end killer....
Old 09-20-2008, 06:32 PM
Johnnystock's Avatar
humm, not worth it, go for another 50 for the trouble I'd say...and after it wont be enough anyway
Old 09-21-2008, 09:52 AM
BOLO's Avatar
Anyone else running an LT1 stockbottom spraying more than 150 shot? What other safety precaution to take?
Old 09-22-2008, 02:50 AM
94FBIRD's Avatar
Get a progressive controller so that you don't hit it all at once.
Old 09-22-2008, 08:23 AM
Stroked96Bowtie's Avatar
Thats prolly the best bet...or break it up into 2 stages like also mentioned. The initial hard hit is whats rough on motors (any motor). If you can bring it on slowly or break it into 2 stages it gives you much better odds of it holding.
Old 09-22-2008, 03:57 PM
87silverbullet's Avatar
Make sure your ignition is up to snuff. Those lt1's are not known for good ignitions especially when you start to raise the cylinder pressure like that. But just like everyone here has said make it a progressive shot but that eats up solenoids or make it a 2 stage setup. Harris speedworks makes an awesome progressive controller give them a shout.
Old 09-26-2008, 12:29 AM
robsquikz28's Avatar
do it
