Before I sell my 10 bolt questions???
What all needs to be kept from the 10 bolt to swap over to the new housing? I will be eliminating my abs/tcs so reluctor rings will stay with the old housing. My main concern is the black backing plate and the silver alum housing behind that. It is the part the brake caliper and bracket bolt to as well as the e-brake cable gets attached to. Is that considered the backing plate or is the thin black circle the e-brake pads rest against considered the backing plate? Thanks for the help guys. I will most likely sell this one before I order my new one and do not want to miss anything. It is already out of the car so I have pics if needed. Thanks again.
Buy new backing plates which will come with all of the e-brake provisions.
What rear are you going with?
My Fab 9" from Midwest Chassis actually has factory style clips on the axle housing for the brake lines as well as for the e brake cables. It also allows for use of stock sway bars and comes with mounting points for it... very nice setup.
