sway bars worth it??
Old 09-20-2008, 08:22 PM
408Maro's Avatar
Default sway bars worth it??
so im debating on getting the bmr 35/22 set up because the price is good. does it really matter if i get them or just save my money? im just hitting the track once in a while and just DD it. i got tq arm,sfc,lcas,phb & relocation brackets should i get something else or would this help me out? thanks
Old 09-20-2008, 08:38 PM
michaelg589's Avatar
Well i was gonna say you should go with Strano's sway bar set because they are hollow compared to BMR's which are solid. But I just checked Strano's site and i think they doubled in price since i bought them. So yea, i'd say go with the BMR's. My Strano bars made a very nice improvement. theyre hollow which is stiffer, but those should also perform well.
Old 09-20-2008, 08:45 PM
shady milkman's Avatar
get them..you will not be disappointed
Old 09-20-2008, 08:47 PM
strano is the man...anything extra you pay for his stuff is worth it. multiple scca camp has to know his stuff
Old 09-20-2008, 08:52 PM
ABJ88's Avatar
I thought hollow was a bad thing, with rusting and rotting from the inside. I read something about that a year or so ago.
Old 09-20-2008, 08:53 PM
jsteele90's Avatar
i have a BMR 24mm rear bar with poly bushings and endlinks and a ws6 32mm front bar with poly bushings and endlinks and it made a huge difference over stock.
Old 09-20-2008, 09:45 PM
Elliott's94Z's Avatar
I threw a set of Spohns on my daily driver and they kick ***.
Old 09-20-2008, 09:55 PM
subarubill96's Avatar
totally worth it if you like taking corners, strano bars seem to be the lightest ive come across. id go with those and not look back
Old 09-20-2008, 10:20 PM
CranMaro99's Avatar
Get the Strano set up.
Old 09-21-2008, 07:21 AM
JD_AMG's Avatar
What are you looking to improve? A larger front swaybar will only hurt your 60ft times because of less weight transfer.
Old 09-21-2008, 11:48 PM
Bud M's Avatar
The BMR front bar is 32 mm. Its not a bad bar set, but the Strano front bar is better. I've had both.
Old 09-22-2008, 03:03 AM
LustrousWS6's Avatar
I finally installed my strano front bar after letting it sit for 4 months! OMG - HEUGE difference - the Konis can't even compare to this change... but the Konis may work with the bar so who knows
Old 09-22-2008, 09:10 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
Hello, our sway bars are solid bars that are cold formed. What that translates to is a sway bar that is 40% stronger than a factory bar and being cold formed they resist torsional fatigue better than a hot formed bar. We have a sway bar package that includes both bars and bushings for $349.00. They are in stock and ready to ship. If you have any questions please give me a call.
http://www.bmrfabrication.com/F4.htm
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 09-22-2008, 01:00 PM
F8L_LS1's Avatar
john,
im getting the strano bars once they are in stock. you should get some as well.
Old 09-22-2008, 01:11 PM
LS1TECH Sponsor
Sam Strano's Avatar
Just back at work... I'm behind since I was closed for almost two weeks while I was in Kansas (winning my 5th National Championship). I'll make this short and sweet.
I did my hollow bars they way I did because I felt that was the best combination of size, weight, cost and performance. If you want to save some money, we can do you solid bars in the same sizes (but few opt for these since you are gaining about 20 pounds of weight). Are there other opinions on what "works"? Sure. But I'm not one-trick pony. You want a 32mm bar? A solid 22 rear? A 25mm rear? I have all of those too.
FWIW, the stock GM front bars are all hollow....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Quick Reply: sway bars worth it??
