Generation IV Internal Engine - Modified LS3 vette owners come in
View Full Version : Modified LS3 vette owners come in
Bad93TA
09-20-2008, 10:21 PM
A buddy of mine just got an 08 vette with the ls3. He put a cold air intake on it and OnStar kept calling him because his check engine light stays on. How do you guys get around this? Tune it out of the comp??
Summerwolf
09-20-2008, 11:10 PM
did he disconnect the battery cable and make sure all the clamps are tight/sensors plugged in?
Bad93TA
09-20-2008, 11:16 PM
Im not sure he just said after he installed it OnStar kep callin him becasuse his check engine light was on so he took it off. Im sure he installed in correct. If he didnt disconnect the battery the check engine light would come on?
Summerwolf
09-20-2008, 11:20 PM
the battery disconnected will clear the code and upon startup the computer will learn the new parts....sometimes it works sometimes it doesn't.
Bad93TA
09-21-2008, 12:04 AM
and if it doesnt??
I just realized i put this in the internal engine section. Mods feel free to move it... sorry
abbaskhan
09-21-2008, 12:16 AM
we had the same problem but onstar has yet to call car even studdered bad it seems o8 computer is SENSITIVE
Bad93TA
09-21-2008, 12:32 AM
hmm did you disconnect the battery like Summerwolf said?? Im going to tell him to try that...
AU N EGL
09-21-2008, 07:01 AM
disconnect OnStar
Bad93TA
09-21-2008, 11:02 AM
disconnect OnStar
How do I do that? And what if he really has a problem, can he reconnect it?? Did you have this problem also?
