Bottle heater problem
Old 09-21-2008, 10:39 AM
99ccz28's Avatar
Default Bottle heater problem
My bottle heater will only come on if there is no nitrous in the line and the bottle is closed. If there is nitrous in the line it will not come on. If I close the bottle and purge it a bit it will then come on. Any suggestions? Thanks
Old 09-21-2008, 11:09 AM
Dragman's Avatar
sounds like it has a pressure sensor on bottle! If so most has a adjustment for on & off.
Old 09-21-2008, 08:04 PM
myfast70's Avatar
Check the wiring on the relay. It sounds like you wired it to the noramlly closed side of it. You trigger wires should be connected to pins #85 & #86 and your heater wires should be #87 & #30.
Old 09-22-2008, 12:45 PM
Nitro Dave's Nitrous Outlet's Avatar
What type of heater is it. What pressure switch are you using?
Dave
Old 09-22-2008, 03:35 PM
99ccz28's Avatar
HSW heater. Pressure switch? not sure.
Old 09-22-2008, 04:38 PM
myfast70's Avatar
How do you have it wired? Do you have a diagram or picture? What pin do you have the heater connected to on the relay? It still sounds like the heater is connected the the relay wrong. Post some wiring info!
Old 09-22-2008, 04:53 PM
Nick@HSW's Avatar
Did you follow the attached diagram in the instructions? If you don't have them to double check, shoot me an email and I'll send them to you.
Nick
Old 09-22-2008, 08:41 PM
99ccz28's Avatar
I will check all the wiring out. I did not install it so I am unsure of it at the moment.
Old 09-23-2008, 09:34 AM
Nick@HSW's Avatar
Sure not a problem. Shoot me a PM once you get a chance to look it over and we'll go from there. Thanks!
Nick
Old 10-01-2008, 09:25 AM
99ccz28's Avatar
Bottle heater was wired wrong. Not that I am surprised. All the shoty work that was done on this install, from a sponsor too.
Old 10-01-2008, 09:53 AM
Nick@HSW's Avatar
Glad to hear you got everything worked out!
Nick
