Can abs codes be deleted?
Old 09-21-2008, 02:58 PM
03 BUSA's Avatar
Default Can abs codes be deleted?
Looking at running a spool and abs delete. Can all the codes for the abs/tcs system be deleted without perfoming the pin swap method. Just have the codes turned off like the evap and egr system codes? Did a search just haven't found my answer. Thanks in advance.
Old 09-21-2008, 04:13 PM
slow's Avatar
no, since it is a seperate module.
Ryan
Old 09-21-2008, 04:38 PM
03 BUSA's Avatar
Thank you.
Old 09-23-2008, 08:12 PM
DrkPhx's Avatar
Like mentioned above you can't delete the ABS codes because it's controlled by the BCM. However, you can "jumper" the pins on the ABS module connector to keep the light from illuminating on the dash for 98's.
Old 09-23-2008, 08:16 PM
blackesteyes8696's Avatar
just take the light bulbs out of the gauge cluster
