1/4 mile
Old 09-22-2008, 03:13 PM
z28camaro1090's Avatar
Default 1/4 mile
what do you guys think i will run at cecil dragstrip in md on friday all mods in sig
Old 09-22-2008, 03:15 PM
10.5LT1's Avatar
13.3@98
Old 09-22-2008, 03:18 PM
QWIKWS6's Avatar
Old 09-22-2008, 03:27 PM
my hope was to break into the 13's.. after i go down im gonna put a shift kit,headers, and eibach drag springs with some sort of adjustable shocks. the reason i think it might the motor and tranny were rebuilt less then 40k ago
Old 09-22-2008, 03:36 PM
EliteCamaro94's Avatar
bone stock i went 14.3 at a track here in az, so since you have a few more performance upgrades you should break into the high 13's as long as you get a good launch and 60' time. Good luck and let us know what you run.
Old 09-22-2008, 03:41 PM
19mike84's Avatar
13.90's
Old 09-22-2008, 03:43 PM
meanredZ's Avatar
13.8 @ 100
Old 09-22-2008, 04:00 PM
thanks guys.. me and my friend who is a ford guy chevy hater have a bet i got i will go 13's he says i wont break 14.0 so hopefully the lt1 can shut the ford *** up
Old 09-22-2008, 04:18 PM
what kind of time would i look to knock off with a shift kit alone like .1-.3 sec? and with the mods i talked about earlier i was thinking i should get under mid 13's..
Old 09-22-2008, 04:34 PM
kinglt-1's Avatar
13.8's now, the shift kit and drag radials should get you in the 13.4 range. then add headers and gears, you should see upper 12's. Then a cam, for mid low 12's. then rebuild the motor and do h/c/i from le, should see mid 11's. It's a viscious cycle LOL!
Old 09-22-2008, 04:40 PM
BigZee71's Avatar
My 93 auto with 2.73's, hot cam kit, headers and CIA with a tune ran 13.6 @105 with a 2.1 60ft on DR's. Damnit I need gears! and a staaaaaall!
Old 09-22-2008, 04:49 PM
you must have had bad conditions?
Old 09-22-2008, 06:33 PM
z28rob18's Avatar
ima gonna say 13.8-14.0
Old 09-22-2008, 10:38 PM
depending on when the shift kit gets here that may be in the car before hand
Old 09-22-2008, 10:59 PM
Goat2NV's Avatar
I think you'll make 13s for sure. My 94 Formula went 14.27 @ 98 mph on a 2.2 60ft, with a K&N panel filter. I honestly thought the car was gone stock, til I looked in the air box. This was in the heat of Aug. Oh and at Capitol Raceway.
Old 09-22-2008, 11:08 PM
AChotrod's Avatar
13.9-14.2 depends on the condition of the car and track.
