what system gives better results tnt ring or plate?
Old 09-22-2008, 07:43 PM
camaro 1999's Avatar
Default what system gives better results tnt ring or plate?
i have a tnt ring nitrous system and i was wondering would i get better results with a plate system
Old 09-22-2008, 09:10 PM
VTC_WS6's Avatar
I don't know about result perse since I had to ditch my ring setup, but god help you with the fitment!! Nothing but praise since I switched to a plate kit.
Old 09-22-2008, 09:55 PM
myfast70's Avatar
Not sure if you will actually see a gain in horsepower but the HSW plate has the best distribution out there.
Old 09-22-2008, 10:11 PM
transam69230's Avatar
plate kit is a good choice
Old 09-22-2008, 11:12 PM
chetmo's Avatar
after alot of research i went with the N20 outlet plate.
Old 09-23-2008, 09:27 AM
ShiznityZ28's Avatar
Nitro daves plate has a very nice spray pattern.
Old 09-23-2008, 09:36 AM
Nick@HSW's Avatar
Honestly, what are your goals with the system?
Nick
Old 09-23-2008, 10:39 AM
chetmo's Avatar
IMO HSW or n20outlet plates are both nice, I have a mix between the 2 companies on my kit, but the n20outlet plate, simply because of there jetting/fitting location aimed towards the back of the car, and that was exactly what I needed. Both have put alot of time and research into the plates though!
Old 09-23-2008, 10:48 AM
Chris@NitroDaves
Guest
Posts: n/a
Our plate will net you better results over the TNT ring in the fact that we are breaking the discharge down into 6 for Nitrous and 6 for Fuel. Where the ring being it uses nozzles only nets you 2 discharges for Nitrous and 2 for fuel. The plate will get you better atomization and more even cyl distribution.
Here is an example that a customer did of our plate.
View Video on FQuick
-Chris
Old 09-23-2008, 11:57 AM
chetmo's Avatar
WOOT WOOT! i love those videos, they dont get old!
Old 09-23-2008, 12:13 PM
8 second mod
Noyzee's Avatar
i like the plate better, it might not net power, but i think it will work better and safer.
Old 09-23-2008, 02:06 PM
myfast70's Avatar
Here's a vid of an HSW plate. Which way would you go? It seems to have better distribution into the intake and is does not have a "wall of nitrous" that will disrupt the incoming airflow.
Old 09-23-2008, 07:04 PM
AlexLs1's Avatar
I have the Nitro Dave's plate kit and love it, it makes great power; it makes more power than a friends car who has the TNT F1 kit when we both spray a 150 shot and our motors are almost identical.
Old 09-23-2008, 07:45 PM
motoxlifer's Avatar
Not trying to dog anybodies product, but it seems like the n2o outlet plate is spraying more downward and actually accumulating on that white thing in a big frozen clump. Now wouldn't that be doing the same thing on your intake or the top of your throttle blade? Just my opinion but I think I would rather it spray more horizontally backwards into my intake. jmo though
Old 09-23-2008, 07:53 PM
Nitro Dave's Nitrous Outlet's Avatar
Good question..
I am currently working on something that will explain and better show those who do not understand how the intake flow in the throttle body works as well as the vacumme pulled by the cylinders. Ill let you decide for your self just how well our plate design works. We did our home work very well before releasing our plate design years ago.
There is a reason why our plate distributes so well reaching HP levels of 400 HP with out delivery restrictions in the fuel or nitrous side.
Stay tuned...
Old 09-23-2008, 08:03 PM
motoxlifer's Avatar
I'm new to nitrous and this stuff is very interesting to me. I'll be waiting patiently.
Old 09-23-2008, 09:15 PM
with my tnt ring kit the car would run lean some times i was spraying a 300 shot on it and i had a stand alone for the nitrous kit and a good tune and i had been seeing how people said that the plate system works real good
Old 09-24-2008, 10:35 AM
When you say it was running lean. Was the over all tune up running lean or just certain cylinders from poor distribution?
Dave
Old 09-24-2008, 04:47 PM
certain cylinders
Old 09-24-2008, 04:56 PM
Nick@HSW's Avatar
I wouldn't even recommend a plate or nozzles for that large of a shot. I'm sorry to say it but it looks like you might have to bite the bullet and finally spring for a direct port system so you can address the distribution issues you're already having.
Nick
