MY FJO/ZEX 908 window switch went out.....
Old 09-23-2008, 11:30 AM
stevegrizzle's Avatar
Default MY FJO/ZEX 908 window switch went out.....
I thought these things were bullet proof........everything worked great and one day it just stopped.
I couldn't figure it out for the life of me but when I disconnected the window switch it worked fine.
I tried setting the rpms to 000 on activation and hit the wot switch with the car off and running and nothing. (tach signal was dead on)
Anyone have any ideas.......maybe fjo will give me credit towards a new mini progressive controller........
Old 09-23-2008, 11:41 AM
860 Performance's Avatar
I know that kills the older ones every time.
I'm not sure if they are still built like that or not.
Old 09-23-2008, 05:01 PM
it stopped working before I tested that, obviously.......
Old 09-24-2008, 10:50 AM
Nitro Dave's Nitrous Outlet's Avatar
Steve,
Try setting the activation at 1500 or more when testing.
Double check all your connections and make sure you did not have a wire connection work loose. If you have a fuse in the system check it.
Then if all else fails call ZEX tech to send in to be checked and warrentied.
How long ago did you buy it?
being it is an electrical component there is always a chance of it going bad. Its possible it did.
Dave
Old 09-24-2008, 11:26 AM
^ I had it set @ 3200 when it stopped working................so initially I tried revving the engine up with the lid off and pressing the wot switch, it didn't fire.....
Old 09-24-2008, 11:35 AM
Ok check the wiring connections and grounds to see if anything worked loose. You should be able to send it in and have it bench tested.
Dave
Old 09-24-2008, 02:42 PM
I checked everything..... tach and all is right on ...... the kit functions without the window switch....
Where can I send it to? is it zex or FJO?
Old 09-25-2008, 09:29 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
If you have the ZEX traction control window switch you will need to contact ZEX to start a warranty claim.
Old 09-25-2008, 10:07 AM
"CWS 0908 SER#1100
908 Window Switch , dual channel"
is what it says on the bottom, not sure which company it came from....but fjo makes them both right?
Old 09-25-2008, 10:19 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
who did you buy it from?
Old 09-25-2008, 10:32 AM
A local performance store.
Old 09-25-2008, 10:41 AM
Sprayed 99's Avatar
did u try to reset the controller? worked for me
Ray@Nitrous Outlet
Guest
Posts: n/a
sorry for all the questions but I am trying to figure out which brand WS you have.
if you bought it new, it should have have had some documentation that came with it....(instructions)....do you have anything that shows a brand name. The unit will have to be sent back to the "manufacturer" for warranty work.
If you don't have any documentation for it you might be able to contact the place you got it from and they could tell you where they got it.
Old 09-25-2008, 10:50 AM
how do i reset it?
Old 09-25-2008, 10:51 AM
I got nothing and the place I bought it from is no longer in business.
Old 09-25-2008, 11:16 AM
Ray@Nitrous Outlet
Guest
Posts: n/a
PM sent
Old 09-25-2008, 03:24 PM
thank^s
Old 09-25-2008, 03:27 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
what does the display show
system on (X.X.X)
inside rpm window (X.X.X)
at wot (X.X.X)
0 = inactive
1 = active
L = locked out
first digit is TPS
2nd is stage 1
3rd is stage 2
Old 09-25-2008, 03:31 PM
it only has one stage and 5 wires :dunno:
2 white
red
black
green
display reads zero on every screen until the deactivation point screen which is set to 060
Old 09-25-2008, 03:37 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
"CWS 0908 SER#1100
this made me think it was not the ZEX...therefore all the questions...the ZEX is a single channel
This is a ZEX unit...contact ZEX and they will get it handled for you
1-888-817-1008
not the programming screens
what does it show when you first turn on the box? Should be 0.0.0
then when you give enough throttle to get above the activation point...needs to be set above 1000 RPM Should be 0.1.0
then when you are at wot....can be tested with the engine off, but key on. Should be 1.0.0
Quick Reply: MY FJO/ZEX 908 window switch went out.....
