When nitrous goes wrong, Kabooom!!!
Old 09-23-2008, 11:58 AM
Village Idiot
JIBBBY's Avatar
Default When nitrous goes wrong, Kabooom!!!
Check out this nitrous explosion vid...
http://www.poetv.com/video.php?vid=3358
What do you think caused this explosion and destruction of this motor.. I feel bad for this guy...
Old 09-23-2008, 12:10 PM
8 second mod
Noyzee's Avatar
ouch for sure
Old 09-23-2008, 12:33 PM
cheddar's Avatar
HAHA that would suck
Old 09-23-2008, 12:56 PM
TWS
TWS's Avatar
Little duct tape and super glue and it'll be fine. It's a Mustang.
Old 09-23-2008, 12:58 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Low RPM activation resulting in a back fire......this is why you want a window switch.
You can hear them let the RPMs drop before going WOT after shifting to 4th
Old 09-23-2008, 01:11 PM
EW1
EW1's Avatar
go, go, go, go shortee it your b-day, you goin to need a new motor for your b-day. Nice still of the explosion though...
Old 09-23-2008, 01:21 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
That video is ancient, but still amusing.
Old 09-23-2008, 01:22 PM
The Manalishi's Avatar
OUCH! That sucks.
Old 09-23-2008, 03:15 PM
RacerXLs1's Avatar
That sucks for him.
Old 09-23-2008, 03:30 PM
bigblock4-speed's Avatar
I dont feel bad- its there stupidity.. a 305rwhp car(basically stock) and trying to add a ton of nitrous to it 100-200 shot? ya- thats stupid..
Old 09-23-2008, 03:45 PM
krazy4's Avatar
That is not a ton of nitrous.
It wasn't the amount of power they added with the nitrous, it was that they sprayed at to low of an rpm.
When I sprayed my car, I went WOT at about 3,500-3,700rpm.
Old 09-23-2008, 05:00 PM
Village Idiot
JIBBBY's Avatar
I spray at idle everytime for the last six years..Sometimes in second gear too... Idle is at1500rpms in my car and I have never had a problem.. Just lit it up right from the start, power and tires spinning..... 100 shot though, tuned to run a little rich with cool running spark plugs... No problems at all to report....
I don't see why low rpm nitrous activation would be a problem? Maybe someone can enlighten me on this?
Old 09-23-2008, 05:01 PM
blwn_00gt's Avatar
so if yours was to blow with a 100 shot are you stupid? ive seen plenty of ls1/ls6 intakes do the same thing..
Old 09-23-2008, 05:03 PM
blwn_00gt's Avatar
the ford modular intakes dont really flow that well and it cause the fuel to puddle up in the intake and BOOM there you go..
Old 09-23-2008, 05:09 PM
First off- i would never run nitrous, and there are plenty of guys on here- that have run that amount - and not had problems with there ls1/ls6/fast intakes.. id have to say they didnt have the system setup right in the first place- for the intake to blow off that quick..
Old 09-23-2008, 05:27 PM
blwn_00gt's Avatar
thats what happens when someone doesnt use a window switch and turnes it on to early.
the ls1/ls6 intakes flow better than the modular one do so thats why they have more problems blowing them on the spray, but gm intakes will blow also..
Old 09-23-2008, 05:29 PM
Banned Village Idiot
LS1BLKSS's Avatar
Old 09-23-2008, 05:37 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Old 09-23-2008, 05:45 PM
Never said that they cant blow up..
Old 09-23-2008, 06:54 PM
Race your car!
JL ws-6's Avatar
I don't have a window switch on my car, but I have a converter that goes to 4200 on the brake, so it's never seeing less then 4200, the rev limiter is set at 7800 and I shift it at 7000, so it never sees that either.
With a stick car, there's no way I'd not have a window switch on the car, but with a loose converter/automatic car, I wouldn't bother as long as the shift point is a good distance from the rev limiter.
