LS1 and 200-4R
Old 09-23-2008, 07:36 PM
wiseman79's Avatar
Default LS1 and 200-4R
I'm trying to run a 200-4r behind an LS1. I'm likely to go carb but am trying to explore how to make this swap while keeping it injected as another possible route. The issue I'm stumped on is the TV cable. Do you need a custom length cable, do those even exists? Also is there any TV bracketry available or diagrams for building them? Has anyone done this already?
Old 09-23-2008, 07:51 PM
bluethunder364's Avatar
I have a 200-4R behind my LQ-4 with a carb. Try Bowtie Overdrive. That is where I got my set-up from. They have nice componets, little pricy, but nice. Sure they must have a set for fuely
Old 09-23-2008, 08:01 PM
wiseman79's Avatar
Yeah that's where I got the trans. I'll check their site for LS stuf. When I bought the trans a month or so ago I was planning on putting it behind the existing 350, but a deal on an LS1 changed all that this past weekend.
Old 09-23-2008, 08:16 PM
wiseman79's Avatar
You were right!...http://www.tvmadeez.com/ls1_cam/
Old 09-25-2008, 07:03 AM
LS1MCSS's Avatar
Originally Posted by wiseman79
The tvmadeez hookup will work on 98 and 99 throttle bodies. It won't mount on 2000 and later throttle bodies. The have a larger side plate. I learned this the hard way. If your throttle body is 2000 or newer or aftermarket, you'll have to build your own connection point. If you have to do it this way, let me know. I have a link with the correct geometry for the connection.
