Fox body, AJE K member, LS2, Kooks 1 7/8, which oilpan?
Old 09-24-2008, 09:19 AM
Crawlin Z's Avatar
Default Fox body, AJE K member, LS2, Kooks 1 7/8, which oilpan?
I'm thinking of putting together a 6.0 for an 85 Mustang with an AJE K member, Kooks 1 7/8" headers, it will be carbureted and I will probably be shifting it at 7k+, intended for street/strip. Which oilpan(s) fit and will give me the best options as far as oil control, capacity, windage trays etc? I know an F body pan would probably fit, but I was wondering if there was anything better out there, stock or aftermarket. Also, if anyone has any other experiences/ideas about K member and header choices I'm open to other options. Thanks-Nick
Old 09-24-2008, 11:03 PM
jw33's Avatar
F-body. Simple, cheap, and works.....
Old 09-25-2008, 05:18 PM
NO 5.0's Avatar
+1 on the f-body oil pan.
Old 09-25-2008, 08:17 PM
Slow 346's Avatar
F Body pan, AJE K Member and Kooks headers here on my Fox....all work perfect together. The Kooks header is awful close to the factory trans crossmember mount on the drivers side of the car. Anyone else have this problem?
Quick Reply: Fox body, AJE K member, LS2, Kooks 1 7/8, which oilpan?
