new set up
Old 09-24-2008, 12:30 PM
SCott5's Avatar
Default new set up
well i finally just sat down today and put my setup down on paper to take a real good look at it so i figured i would share and see what your opinions are.... Here ya go
Motor:
Ported heads (upgraded springs and valves)
matched intake
custom cam
30lb injectors
ac and smog delete
pacesetter lts
x-pipe into true duals
58mm tb
new plugs, wires, opti
cai
1.6 pro magnum rr's
spray after a while
Suspension/Chassis:
subframe connectors
6 point cage
draglite slicks and skinnys
tubular k + a-arms
eibach drag launch kit
new shocks and sturts
drivetrain:
3500 stall
1/4 mile time - ???
here is my current setup
o/r y pipe
flowmaster cat-back
2500 stall with built tranny and shift kit
3.73s
1/4 mile time- 13.5 @105
Old 09-24-2008, 01:19 PM
10.5LT1's Avatar
depending on the size cam i would say 11.7s-12.0s
Old 09-24-2008, 06:09 PM
Dave J's Avatar
Sound right about right
Quick Reply: new set up
