9" in 3 channel (non traction controle) car?
Old 09-09-2003, 12:47 AM
2001CamaroGuy's Avatar
Default 9" in 3 channel (non traction controle) car?
HOW do I do it?
I REALLY REALLY want a 9" but only have 3 channel ABS in my car.....
Old 09-09-2003, 07:44 PM
42NightZ28's Avatar
Default Re: 9
you can have a 9in but your going to have to give up ABS to do it.
Old 09-09-2003, 08:13 PM
LOnSLO's Avatar
Default Re: 9
One thing you could try is to get an exciter ring pressed on one of the rear axles. Then get a backing plate from a 2001+ TCS car and put it on that same side. Then just splice the two wires over to the sensor. If it works, you'd at least have it on one wheel, FWIW
Old 09-09-2003, 09:19 PM
96-speed's Avatar
Default Re: 9
A guy off of camaroz28.com did it successfully. He used a gear from a forklift or something, mounted it on the driveshaft and then mounted a bracket for the sensor on the transmission. Pretty slick.
I'm not sure if the amount of teeth on the gear/position ring matters as long as there is a constant reading to the sensor.
He had pics, but I don't have them anymore, and I don't remember his name.
You can do anything you want with some research .
Ryan
Old 09-09-2003, 11:44 PM
Default Re: 9
gear....as in GEAR GEAR (like in a tranny or something) or was it a reluctor wheel (like would be for ABS)?
Old 09-10-2003, 12:59 PM
KRAZY K 2000 TA's Avatar
Default Re: 9
Im pretty sure mosers axles have the reluctor ring on there axles if u by a moser axle and housing.And dont listen to every body badmouthing moser only the few with problems are going to speak up,but they have a right to they did spend alot of money on there product,Mine does not leak.I called moser about the ford 9 and asked them numerous ? about the rear end. by the way 9s are great i am as we speak building another center section right now with a spool and 4.33s
Old 09-11-2003, 03:32 AM
35th SS's Avatar
Default Re: 9
just take it off your 10bolt and transfer to the axles for the 9inch.
Old 09-11-2003, 08:34 AM
LOnSLO's Avatar
Default Re: 9
That won't work as the axle sizes are different. Plus, he doesn't have reluctor rings on his, since it's a 99.
