97 vette fuel rail swap
I have a 97 corvette with return style fuel rail. I am changing the engine out for a LS7 based 427. Should I change this system out to the newer style or will this be sufficient?
No the stock 98 rail will not fit that intake. We make billet rails that will fit those intakes. What car is it going into? Give me a call I will be able to set you up with the correct parts you need to make it work.
Nate
Nate
i had a 97-98 vette fuel rail for my old combo. i went with a L76 intake and was able to reuse the 97-98 vette rail to work with the L76 intake. i tweaked the mounting tabs alittle and added a nylon spacer to take up the distance.
sorry pic isnt the best quailty but you can see how it works
