rear end making noise
Old 09-24-2008, 11:20 PM
00 SiLvEr SS's Avatar
Default rear end making noise
ok so heres my problem every time i go around a corner above 20 mph and let off teh gas as i turn i hear a knocking/vibrating/funny sounding noise ne one kow what it could be
Old 09-25-2008, 12:22 AM
SS1875's Avatar
Is it from the front or the rear?? Pretty vague...need more info to really give you any good answer. But you could start by checking bolts/nuts, basically any moving part for wear or failure.
Old 09-25-2008, 12:36 AM
my bad its coming from teh rear everythings tight and the struts and shicks are brand new im kinda worried its the locking mechanism in the diff
Old 09-25-2008, 12:52 AM
SS1875's Avatar
Have you checked the u joint?? Check your caliper bolts?? Stock 10 bolt or aftermarket rear??
Old 09-25-2008, 08:45 AM
the whole car is stock except for the engine bolt ons
Old 09-28-2008, 02:23 PM
INMY01TA's Avatar
do a search for "can of marbles" or "marbles". This noise is normal and nothing to worry about.
Old 10-05-2008, 04:31 PM
it doesnt sound like nails cutting through paper like some of those articles say it sounds like a knocking noise whenevr im turning and let off the gas ne other ideas guys
Old 10-05-2008, 07:17 PM
SS1875's Avatar
Increased backlash due to sloppy bearing? any leaks around the diff?
Old 10-05-2008, 09:32 PM
not that i can see i mean we replaced teh outer wheel bearings so im not quite sure what it could be no leaks from what i can see how do i check the backlash
Old 10-05-2008, 09:41 PM
now at idle i can hear the motor making a ticking noise. ne ideas guys
