Nitrous help?
Old 09-25-2008, 01:03 PM
10.5LT1's Avatar
Default Nitrous help?
This is the first time i have ever considered sprayin a car but i just read somewhere that the stock LT1 PCM is to slow to recognize t nitrous through the maf with a dry kit? what kinda truth is there to that?
Old 09-25-2008, 01:15 PM
Elliott's94Z's Avatar
Go with the wet Nitro Outlet Plate set up or the NX! Best on the market.
Old 09-25-2008, 01:24 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
You are correct about the LTx PCM not being able to handle MAF based dry kits.
LT1 dry kits are designed to spray behind the MAF, then they increase the fuel pressure at the regulator to add the extra fuel.
For LTx cars I would run a wet kit.
Old 09-25-2008, 01:27 PM
http://www.nitrousoutlet.com/catalog...el=135&dept=11
Old 09-25-2008, 02:03 PM
10.5LT1's Avatar
what do you think of this kit? http://www.nitrousoutlet.com/catalog...roduct_id=3204
Old 09-25-2008, 02:09 PM
Originally Posted by 10.5LT1
Same kit I am getting but you should get some other goodies to go with it like the window switch, NGK TR6 plugs, fuel pressure saftey switch. I'm also doing the purge kit, ashtray plate, throttle body plate kit and the bottle bracket that mounts where your spare tire and jack go.
Old 09-25-2008, 02:14 PM
10.5LT1's Avatar
I never really understood the purpose of a window switch. what are some of the benefits and is it a most for that kinda setup? yea but i goin to get the plugs?
Old 09-25-2008, 02:33 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
I would not run a nitrous kit without a window switch.
It prevents low rpm activation and will shut the nitrous off in an "over-rev" situation. This can be caused from tranny/clutch slippage, drive line breakage, miss shift, etc. You can also use a window switch to shut the nitrous off in between shifts to save transmission wear also.
Old 09-25-2008, 03:10 PM
^^ exactly..there's a LS1 guy around here that had to rebuild his tranny because he didn't have the switch.
Old 09-25-2008, 03:29 PM
10.5LT1's Avatar
can i buy a kit that comes with nozzles and instead use a plate? i would rather use a plate?
Old 09-25-2008, 03:34 PM
http://www.nitrousoutlet.com/catalog...roduct_id=2807
Old 09-25-2008, 03:43 PM
Ray@Nitrous Outlet
Guest
Posts: n/a
Originally Posted by Elliott's94Z
.........you beat me to it
Old 09-25-2008, 04:09 PM
Lol I got all the parts in a email Chris sent to me so I quick on the draw! Do I get a discount on your items since I'm pushing them Jk
Old 09-25-2008, 04:16 PM
Quick96ss's Avatar
I run Nitrous Outlet's Plate Kit! It's great and the results are amazing! Anything you buy from them is great. And the Service is Some of the BEST i have ever worked with!!
Old 09-25-2008, 08:05 PM
zlicious94's Avatar
OOHH.... cant wait for mine! lookin like the complete lt1 plate package is gonna work great for my ride
http://www.nitrousoutlet.com/catalog...roduct_id=2809
Old 09-25-2008, 09:10 PM
Wish we would have had it last weekend when we ran the Turbo Talon the kill would have been that much sweeter
