4ch to 3ch question
Old 09-25-2008, 08:17 PM
Ilikeppie's Avatar
Question 4ch to 3ch question
so im looking at swapping my 3ch out for a 4ch to go to the track tomorrow so my question is what if i dont drill the hole in the housing for the abs sensor what would happen if i drove it without that sensor hooked up? will my speed o meter still work im assuming that my abs will be inoperable but other than that it should be ok to run it this way right?
Old 09-26-2008, 04:20 AM
EPP
EPP's Avatar
If you don't hook up the sensors, all that will happen is that your ABS and TCS won't work. Your brakes will still work just fine, you just won't have ABS. The traction control won't work either. The speedo will still work just fine. Bob
