4.8 injectors?
Old 09-26-2008, 12:31 AM
1320's Avatar
Default 4.8 injectors?
ok, I searched, I tried performancetruck.net and I googled it.....
What is the rating on the 2004 4.8 truck injector?
It appears the 6.0 is a 24.8 lb per hr injector, what about the 4.8
Old 09-26-2008, 05:52 AM
FICINJECTORS's Avatar
ACCORDING TO MY INFO THE FOLLOWING VEHICLE USE THE SAME INJECTOR.
2003-04 Express, Trailblazer 5.3
2003-04 Envoy, Savanna 5.3
2003-04 Express 4.8
2003-04 Savanna 4.8
2002-04 Denali 6.0
2003-04 Express, Silverado 6.0
2003-04 Savanna 6.0
2002-04 Alvalanche 5.3
2001-04 Silverado, Suburban, Tahoe 5.3 (T)
2001-04 Sierra, Yukon 5.3 (T)
2001-04 Silverado, Tahoe 4.8 (V)
2001-04 Sierra, Yukon 4.8 (V)
2001-04 Silverado, Suburban 6.0
2001-04 Sierra, Yukon, Denali 6.0
2004 SSR 5.3
2004 Envoy 5.3
2001-03 Silverado HD 6.0
2001-03 Sierra 1500 HD 6.0
2001-03 Silverado 2500 5.3
SO I WOULD SAY ITS IN THE PCM AND FUEL PRESSURE THAT CHANGES THE CHARACTERISTICS IN DIFFERENT VEHICLES USING THE 3 DIFFERENT ENGINES
Old 09-26-2008, 08:57 AM
1320's Avatar
ok, one more question......
is there a direct replacement injector for the 4.8 truck (2004) in the 40-60 lb/hr area?
Old 09-26-2008, 11:14 AM
kbracing96's Avatar
Yep, the 4.8,5.3,6L after 99 all use the same 24.8lbs/hr injectors. Tuning and fuel pressure is the same for all of them.
8.1 truck injector are the same plug and play (need tuning) and about 31lbs/hr and the 8.1 Marine injectors are 43.8lbs/hr plug and play.
Old 09-29-2008, 10:36 PM
bgblockelcamino's Avatar
anyone ever use the flex fuel injectors? supposed to be rated at 36 or so was thinking about trying them in stock truck intake and change the pigtails.
Old 10-07-2008, 12:09 PM
Closed ex-Sponsor Account
SRT10KLLR's Avatar
The software I use for tuning showed that my 2003 had 25.24 lbs/hr injectors. Are you looking for 40-60 lbs/hr injector at 3 bar(43.5 PSI) or 4 bar(58 PSI) fuel pressure? The ones I had made were 63.4 lbs/hr @ 43.5 PSI and 73.2 @ 58 PSI. The 8.1L Marine injectors flow 37.95 lbs/hr @ 43.5 PSI and 43.8 @ 58.
What mods do you have?
Here is a link to the ones I had made.
http://www.performancetrucks.net/for...d.php?t=416134
You can get the 8.1 Marine units here:
http://www.racetronix.com/17113739.html
http://www.nelsonperformance.com/products.htm#fuel
*Not sure if it's ok to post their link but will remove if needed
Quick Reply: 4.8 injectors?
