Last blot...stripped
I had some of the Pacesetters strip on me. I was able to carefully grind the Heads of them down with the Dremel, and then got the Header to move a little and popped what was left of the bolt right off. Then I took the Header off and removed what was left of the Bolt. The fcked up thing about it is that it came right out by hand..
See if that will work for you. If you can't turn it by hand, Vise Grips will work.
well i got the header off. thanks for everyone's input.
Auto zone sold me this piece that took it off.
now that the header is off, however how am i supposed to get it in?
I took of the starter and dip stick. do i need a lift? to lift my car?
