OLFA table adj. in PE area
Hey
If you get your car tuned with a WB with the OLFA table set to 1.00 for tuning and I have my PE set to command 12.77 AFR, now with my MAF table right on with the WB if I set the OLFA table back to stock, it commands 12.99 AFR at 80 kpa and above.
Now I know that PE is a OL mode and I think the computer will use the fatter mix. from the OL tables available when in OL so will it use the PE as I set it or would it be safer to change the OLFA table at I would think 70 kpa and above to match my PE AFR of 12.77?
Has anyone really figured out what to do with the OLFA table, some used to say change it accordingly and some say do NOT mess with it...it's been a while sense I have searched and am curious what is thought now.
