Fueling & Injection - Upgraded Injectors on a 347cid H & C car....
Phil99vette
09-09-2003, 06:23 PM
What is the benefit of going to bigger injectors on a basically stock displacement H & C car? I know they are recommended on high HP H & C applications but what are the reasons? Lower duty cycle? More power? Better atomization?
Phillip
Fireball
09-11-2003, 11:00 AM
mine wouldn't keep up after 6500 rpm. went VERY lean
Vents
09-11-2003, 02:11 PM
mine wouldnt keep up after about 4500 or so.. 26# injectors = detonation w/ added power.
AL SS590 M6
09-11-2003, 11:16 PM
So what would be a good sized injector for a heads/cam stock bottom end build?
horist
09-11-2003, 11:38 PM
From the info I got and from what I've seen... FMS 42lb seem to be a good idea... (bought some last week) ... when u go bigger injectors you really need to be tuned for them... so may as well go big!
Louis
09-14-2003, 10:25 PM
That Injector is too large IMO for stock displacement with our fuel pressure.
an FMS/SVO 36# injector will handle the majority of stock CID, NA buildups.
I ran RC 36#er in my 460 rwhp heads/cam car with no issues :)
Fireball
09-15-2003, 08:18 AM
SV0 30# works fine for mine :)
TTtop
09-15-2003, 09:18 AM
I have '01 Z06 injectors on the 383 stroker, I think they are 28#'ers. Working good so far! :D
Louis
09-15-2003, 12:44 PM
30#ers will do the job, but phil wants to spin to the moon ;) I like the added safety up top. Id hate to loose an injector @ 7300!
AL SS590 M6
09-15-2003, 02:59 PM
What about using 28.8s out of an 02 car? Not enough for 400-450rw?
If I need bigger then I'll get bigger. Better safe than sorry.
Phil99vette
09-15-2003, 03:25 PM
Spin me to the moon.....apparently When I dynoed they used garbage weather conditions....I am making more HP than I orginally thought. I probably need 42s
Phillip
Pete2k_Z28
09-15-2003, 06:35 PM
Too large an injector can cause metering problems under low and medium throttle conditions. The proverbial equivilant of driving a finishing nail with a sledghammer; it's just too damn big to get super fine control over. Idealy you would like to keep roughly 80% duty cycle at WOT and max RPM. That provides enough reserve yet still controls part throttle conditions fairly accurately.
horist
09-15-2003, 09:56 PM
I just put FMS 42lb injectors in my car.. almost tuned for non WOT driving (LTRIMS 3.4 now.. my next tune will have them at 0 to -1.6) and haven't had any driveability issues....
I decided that bigger is better... I'm going to keep modding my car.. and w/these 42s I'll be safe for a long time...
though 1 piece of advise I can offer ... 42lb injectors + Stock IFR Tables = bad ass sounding hehe (just can't rev past 1500rpm and car wont idle... and the tail pipe leaks gasoline)
XLR8NSS
09-16-2003, 10:55 AM
Horist - I'm glad you got them in and running good. I tried the stock IFR table with mine also(by accident ;) ). The car would idle for a few seconds and die...WAY RICH!! :eek2:
I've also run the 42# SVO's on a 5.3L truck with NO driveability issues. I bought some bigger Siemens 57#(43.5psi) injectors for something I was going to do. It didn't happen but, I put them in the 5.3L anyway to see how they acted. Absolutely NO problems. They actually drive as well as the little stock truck injectors. :)
These computers are very good at part throttle metering and from my experience with the SVO 42#ers and the Siemens 57#ers these two injectors have NO problems running at very low pulsewidths. Heck, my idle pulsewidths are like 1.9ms with the 57#ers and everything is fine.
Personally I'd just go with the 42#ers and forget about injectors. :) N/A you'll probably only see around a 60% duty cycle on them but, that will leave room for a small dry shot. :D
AL SS590 M6
09-16-2003, 03:01 PM
Thanks for all of the responses. I'm leaning towards bigger is better incase I decide that I need a little NO2 to help me out.
CamaroSS_2002
09-17-2003, 12:44 PM
So if My injector duty cycle is hitting 100% just before where I shift 6600rpm then I need to upgrade my injectors?
CamaroSS_2002
09-18-2003, 11:34 PM
TTT
