cig lighter used for 12 volt?
Old 09-27-2008, 04:21 PM
brandon2000z's Avatar
Default cig lighter used for 12 volt?
if i use the lighter for my nitrous switch can i also use it for the purge or should i only use one switch on the lighter and find another for the purge? (the power is orange right i have my bat out and dont feel like putting it back in yet, to test)
Old 09-28-2008, 04:03 PM
blu byu EH's Avatar
NO you need a switch souce. ex. when you turn your key on, thats is a switch souce. The cig lighter is always on not a good idea!!!!!!!!!!!!!!!!!
Old 09-28-2008, 04:48 PM
Hennytime's Avatar
I tried to use the cig lighter for my heater back in the dumb days. All it does is pop the fuses in the dash, don't bother
Old 09-29-2008, 09:52 AM
Nick@HSW's Avatar
I wouldn't recommend hooking it up to the cigarette lighter. I recommend running an add-a-fuse into the fuse block (make sure you're adding it to a switched fuse) and running the purge off of a relay.
Nick
