Are These Injectors?
on the opposite side there should be a number that starts with 0280------.. if you can get thqat I can tell you. or you could get an ohm meter and check it yourself. low would be 3.8+- high would be 12.8 to 16
THE INJECTOR IS A 35LB RATED AT 37PSI low impedance used on the 2.3 ford turbo engines. you can go to page 57 of this pdf to view all the specs on this. If you can't use them let me know. I can use them
http://www.fuelinjectorconnection.co...flow_rates.pdf
