Really Weird Driveshaft Problem???
Old 09-27-2008, 05:37 PM
DTB_LS1's Avatar
Unhappy Really Weird Driveshaft Problem???
Today I started tearing apart my 9" rear to install a new center section and 35 spline axles and I can't get the driveshaft out of the transmission. The driveshaft came off the rearend yoke fine but will not slide out of the transmission. Has this happened to anyone before and, how can I fix this?
Old 09-27-2008, 06:53 PM
98blueSScamaro's Avatar
i hope you didnt lose a ground make sure your body to motor ground strap is on or it will do this.
Old 09-27-2008, 06:54 PM
and i am installing my new nine right know
Old 09-28-2008, 10:54 AM
DTB_LS1's Avatar
Huh? I'm not sure how losing a ground would keep my driveshaft from sliding out of the transmission?
Does anyone else have some info on how I can get my driveshaft out? It won't move forward or back now.
Old 09-28-2008, 12:16 PM
EPP
EPP's Avatar
I'll bet the splines are twisted on the front yoke, you may have to gently beat it out. Bob
Old 09-28-2008, 12:32 PM
35th SS's Avatar
EPP is right.that thing should just slide right out.
Old 09-28-2008, 02:32 PM
DTB_LS1's Avatar
I finally got it out. I must have left my ***** in my other purse when I tried to take it out yesterday. I gave it a little twist with the car in gear to loosen it up and it slid right out. I checked the splines on both the yoke and output shaft and their fine.
Old 09-29-2008, 02:40 PM
Black 99 Bird's Avatar
I was going to tell you to put your purse down and try it again.
Old 10-05-2008, 10:13 PM
formula98ws6's Avatar
Just went to pull my driveshaft becuse of a vibration. Stock length strange think its to short. and it would not go in had to pound it in. Got it out and the splines are twisted on the yoke. I also took off the tail housing to change the bushing and the rear shaft looks good. Now i need a new driveshaft and yoke. I think i'm going to get A pst from epp this time the right length.
Old 10-06-2008, 04:05 AM
EPP
EPP's Avatar
Thumbs up
Thanks, the extra inch in length makes a big difference. Bob
Old 10-06-2008, 08:30 PM
ShevrolayZ28's Avatar
That's what she said....
Old 10-06-2008, 08:50 PM
DOUBT IT's Avatar
Beat me to it.
Old 10-07-2008, 04:53 AM
EPP
EPP's Avatar
Thumbs up
That may help with the stripper in your sig. lol Bob
