RevXtreme Signature Guages!
This one as a combo analog boost & digital EGT. We offer them in most any combo you could want.
All billet outer construction (no plastic) and your choice of LED colors.
All are Aerospace aviation spec and second to none in accuracy.
Here are the combos we have so far:
Boost/EGT combo gauge 30 PSI Deg F
Boost/EGT combo gauge 50 PSI Deg F or C
Boost/EGT combo gauge 80 PSI Deg F or C
Boost/EGT combo gauge 2 Bar Deg C
EGT/Boost combo gauge
Oil Press/Temp combo gauge 80 PSI Deg F
Oil Press/Temp combo gauge 0-5 Bar Deg C
Fuel Pressure Oil Temp combo gauge
Intake Air Temp Deg F Exhaust Manifold Pressure combo gauge
Vacuum/Boost/EGT combo gauge -30 to 30 In Hg Deg F
Vacuum/EGT combo gauge 0-30 In Hg Deg F
Volts/Water temp combo gauge 10-16 Volts Deg F
Transmission Temperature
We are still working on the A/F wideband....will announce it as soon as we have it priced.
