View Full Version : Moroso Oil Pan (21150)
pewter 01 SS
09-29-2008, 10:47 AM
Installing this oil pan on my car and had a few questions..
when i had the stock pan when i put the wintage tray i put washers then the nuts to put it in place looks like with the new tray you cant do that ( the wintage tray is thicker),are you guys simply install it with the nuts only?
on the stock pan there was a sensor that went to the tray what happens with it?
i havent really checked yet but can you still use the same dip stick?
the new moroso pan has the flange thicker, will i be able to use the stock bolts for it looks like they might be a little short.
Fireball
09-29-2008, 10:51 AM
nuts only on the windage IIRC
stock dipstick is ok
stock oil pan bolts, but Ihad to get different ones (much shorter) for the back two since you don't use those long ones anymore (the two that go into the rear cover)
pewter 01 SS
09-29-2008, 11:56 AM
how about The sensor? cut it off?
Fireball
09-29-2008, 12:10 PM
you lose that sensor. its just a low oil sensor
pewter 01 SS
09-29-2008, 12:20 PM
thanks for the help!
