testing injectors?
testing injectors?
is there anyway to test an injector without it being hooked up to the motor? i have a feeling my injectors are bleeding down and cashing a hard start. i was going to tear down my setup to figure this out.
thanks
thanks
take them off, and get an air tank with a regulator (so you don't blow 80psi to your injectors) and turn it up to around 5-10psi and use a 12v battery and use two alligator clips to do positive and negative on the injector.
something similar to that. you will here them hiss, don't know how much of a test that is though. 2 of mine didn't hiss, we turned the pressure up and tried again and BOOM, damn injector took off, LOL. smacked the ground and it has been working fine since but just be careful.
if you want to get them flow matched and re-built, send them off to RCeng.com
First you can try to ohm test them
http://www.youtube.com/watch?v=_g8PdrT0MCU
We offer our 11 step rebuilding process on them for $15 each
thats very low, anything under 12 is pretty much shot, but since they are all within .5 of each other they just seem like theyre all tired and could use some attention or replacement
Best way to test for a leakdown is to put a gauge on the fuel rail, turn the key on and let the fuel pump prime, turn the key off and see if pressure drops
is it possible all my injectors are bad? or least a good percentage of them? i bought them off ebay and user selling them said 1500 miles on them. i notice there is some scribbed numbers on them. noticed the number when i swapped intake manifolds
