LS7 Injectors on LS1 intake
Hey all,
From my understanding, the LS7 injectors will not work on the LS1 intake because it is a EV6 instead of EV1. No problem really because I can get the pigtail connectors.
My question.... Is there an adapter out there to extend the length of the LS7 injector to work with the LS1 intake/fuel rail???
I ask because I have a set of LS7 Injectors avaliable, and want to use them on my LS1.
Thanks for any feedback....
Hey all,
you can adapt the wiring no problem but the ev14 is 48mm oring to o-ring won't fit and I don't think there is an adapter. Is this what your ls injector looks like?
the ls1 uses a ev6 that is 60mm o ring to o ring. The ls7 uses a ev14 with a uscar plug the ls1 uses a jetronic plug.
its not the o ring itself.. its the space between the o rings or the height of the injector. I have a cnc lathe and we are working on adapters. i have the manifold set up that you have in the shop now.. i will let you know how they work after I get done macining the adapter. don't sell them yet
Thansk
the adapters are done.. they look great and work perfectly, we also have the plug and play wire adapters. Now, you can put the newest design Bosch into any rail configuration as a plug and play
