What Gains have people seen going from 13.8 AFR to 12.7????
Old 09-29-2008, 10:11 PM
Restricted User
1fstGM's Avatar
Default What Gains have people seen going from 13.8 AFR to 12.7????
As the title says. I am just wondering what kind of horsepower gains have been seen from going a full point Richer. Trying to get a feel of how much power a point of AFR is worth. I know it really depends, but I am just trying to get an idea.
Old 09-29-2008, 10:29 PM
98catfish's Avatar
Going from 13.8 to 12.7 is not leaner it is fatter.
Old 09-29-2008, 10:50 PM
Restricted User
1fstGM's Avatar
Whooops, my mistake. Corrected.
Old 09-29-2008, 11:38 PM
98catfish's Avatar
I personally think 13.8 is on the edge. You are probably not going to see gains unless you are detonating (knock). Depending on your combo n/a likes 13.0 to 13.2 at the most. W/ afr that lean I would hope your running lower timing ie. 24d at wot.
With that said every car is different. W/o scanning you wont know.
Doug
Old 09-30-2008, 12:11 AM
Restricted User
1fstGM's Avatar
Its actually at 25* at WOT right now. I have some logs.
Old 09-30-2008, 12:16 AM
98catfish's Avatar
You might be better off w/ 13.0 afr and 27 or 28d, But we'll need your combo!
Old 09-30-2008, 07:58 AM
VTC_WS6's Avatar
The only way to know it to strap it down on the rollers and get some numbers. Personally I saw very little gain from 12.7 to 13.2-13.4 so I run on the safer side at 12.7 with about 25* at VE peak, 27.5* at max rpm. IMO, aim richer and see what the benefit (if any) is to leaning on it little by little, you'll probably be supprised.
Old 09-30-2008, 09:26 AM
Frost's Avatar
Originally Posted by 98catfish
...Depending on your combo n/a likes 13.0 to 13.2 at the most. ....
That blanket statement does not cover the scope of N/A. I have had many cars that make next to nothing when leaning out past 12.6-12.7... and a select couple that wanted to be around 13.2-13.3.
The right AFR for an N/A setup is where it makes the most on the rollers. If all you have is the street, 12.8 is a good place to be.
/end 2cents
Old 09-30-2008, 01:06 PM
98catfish's Avatar
/end 2cents
That really wasn't a blanket statement. I prefaced it by saying depending on you combo. I'm not saying those are perfect for every car just a good place to start.
Just saying Most n/a cars we've had on our dyno worked best at or around 13.0. + - .2
Doug
Old 09-30-2008, 01:12 PM
SSpdDmon's Avatar
/end 2cents
x2
Old 09-30-2008, 03:03 PM
Frost's Avatar
Doug
Sorry, not trying to be a *****
It's true that many of the cars that I tune on an unloaded (dynojet) will make the most at 13ish, but getting the cars on the street or track and making pulls through all 3-4gears and having cylinder temps rise causes knock in most of the cases. There is a somewhat local shop that I regularly get retunes from and the cars all have very high timing and are at 13-13.3:1 AFR. They made good numbers on his dyno for the most part, but actually racing the cars is something else.
Old 09-30-2008, 03:50 PM
LS1Tech Sponsor
hellbents10's Avatar
Couldn't agree more, at the track I like to see 12.4-5:1 at torque peak and closer to 12.8:1 at the shift point.
Old 10-01-2008, 07:01 AM
AINT SKEERED's Avatar
this is exactly how mine did. It made the most power on a dynojet at 13.2/1 and 30 deg timing. at the track it was faster with 26 deg and 12.8/1
These changes were worth 1.5 mph
Quick Reply: What Gains have people seen going from 13.8 AFR to 12.7????
