How can Yella Terra rockers help
Old 09-10-2003, 12:02 PM
MeanWS6's Avatar
Default How can Yella Terra rockers help
What exactly is this mod for? Can it be used in a large CI motor? What about my current setup in sig? What advantages/disadvantages would I see from this particular mod? Any daily drivin issues?
Old 09-10-2003, 03:01 PM
2001CamaroGuy's Avatar
Default Re: How can Yella Terra rockers help
only disadvantage is cost and non-adjustable (if you need adjustable).....besides that they are really good
Old 09-10-2003, 03:04 PM
Nasty N8's Avatar
More stability, full roller smother operation, better valve control, And MUCH quieter.
Nate
Old 09-10-2003, 03:51 PM
LS1Tech Sponsor
Slowhawk's Avatar
Nate
Thats what I was going to say.
Old 09-10-2003, 03:59 PM
the debate on if they quiet the valve train down all that much (if nothing is broken on the stock rockers) is still out...
some people say it gets quiet, others say it didn't.....so...who knows....
but....all the other stuff (More stability, full roller, smother operation, better valve control) are all correct...plus they are more reliable (no bearings comming out like some stock units have done)...
Old 09-10-2003, 04:42 PM
Nasty N8's Avatar
Every one I have installed has gotten a lot quieter and everyone I have sold them to has said they were much quieter. So I don`t see any debating.
Nate
Old 09-10-2003, 05:16 PM
Dave Carney's Avatar
Somebody explain the better valve control to me. The valve rides up and down in the valve guide so.....
Old 09-10-2003, 05:29 PM
1) less mass = less chance of valve float
2) stiffer rockers don't flex as much as the stock units so you get the TRUE 1.7 ratio lift
Old 09-10-2003, 05:31 PM
Stu
Stu's Avatar
Definitely quieter...........Thanks again Nate for holding the GP.
Stu
Old 09-10-2003, 05:39 PM
BigBake's Avatar
Also you do not get the valve being pushed side to side. The roller tip eliminates this action, and pushes directly down as opposed to lateraly riding the valve stem tip.
Old 09-10-2003, 05:50 PM
I just don't see how a valve can move side to side in a guide.
Default Re: How can Yella Terra rockers help *DELETED*
Post deleted by Dave Carney
Old 09-10-2003, 06:11 PM
Technoman64's Avatar
When the stock rocker arm rotates the tip that pushes on the valve wil slide across it as it travels down. The solid tip of the stock rocker arm has friction that pulls/pushes the valve side to side causing the drag. The TRUE roller rocker has a roller tip instead of being solid. The roller tip rotates and does not have this friction acting on the valve tip.
Old 09-10-2003, 07:36 PM
BigBake's Avatar
It doesn't physically move in the guide. But it does have force pushing it at the tip in a lateral motion which puts force directly on the valve guide producing more friction and wear.
Old 09-11-2003, 03:29 AM
Mike K.'s Avatar
One extra advantage also is that you shouldn't have to clearance them if you have non-stock diamater springs/retainers. Figured I'd post this cause of all the rocker/retainer clearance posts lately.
Old 09-11-2003, 05:47 AM
LS1derfull's Avatar
YT's have less mass? Says who? They are heavier than stock! Also Aluminum body is not stiffer than stock steel construction. As for push/pull on valve stem, the radius of the tip of stock rocker is much larger than the roller tip of YT's. This means the sweeping arc generated by stock rocker is more gentle on valve tip and guide than roller tip action, which Warren Johnson claims does not consistently rotate in action. His testing proved it.
Old 09-11-2003, 08:44 AM
Bowtieman4life's Avatar
I have YT and they are lighter than the stock one. Also, they are quieter and you don't have to worrry about dumping the needle bearings. Finally, they are more precise than stock.
Old 09-11-2003, 10:27 AM
quickWS6's Avatar
Yeah, I don't know if they help at all or if they are a complete waste of money, but they are definately lighter than stock.
Old 09-11-2003, 10:32 AM
LS1Tech Sponsor
Slowhawk's Avatar
I believe they are lighter than stock.Only way to tell is to dismantle the YT to just weigh the rocker.
Old 09-11-2003, 12:54 PM
robertbartsch's Avatar
..your forgot the part about being shaft mounted...it helps valve train stability....
i bought them becuase the stock ones tend to gernade and spill their needle bearings all other engine
