service engine soon????
Old 09-30-2008, 09:22 PM
1sick68's Avatar
Default service engine soon????
i was driving to a friends house and my service engine soon light comes on right.... no engine change, no performance decline. just that now it does not go into 4th or over drive.... it does go up and down through 1 2 3, just not into the other gears...... any suggestions...... 94' LT1 camaro....
Old 09-30-2008, 09:27 PM
lt1z28camaro's Avatar
Take it somewhere to run the codes so you know what it's trying to tell you. Midas, Autozone, GM Dealer, etc..
Old 09-30-2008, 09:33 PM
1sick68's Avatar
thats right, but the light turned off. and is it obd1, AutoZone sucks they only have obd2, i used to work there....autozone....... but anything else could be wrong........ any idea's
Old 09-30-2008, 09:34 PM
ThoR294's Avatar
OBD1 is stupid like that.
Old 09-30-2008, 10:24 PM
93lt1M6z's Avatar
can get an idea until ya get it scanned. and is it auto or manual? you said won't go into 4th or OD....but 4th is OD on automatics. so you have 1-2-3 and not OD. possible problem in the trans then with a sensor or something. but like i said get it scanned. gotta pay the cash to have a shop scan it
Old 09-30-2008, 10:34 PM
Does it go into OD after the light goes off?
Old 09-30-2008, 10:37 PM
1sick68's Avatar
yes its auto, and yes nothing into 4th, just 1 2 3 up or down, sometimes in the morning it stay's in first like if its stick, but after i throttle it, it lets go, i think that trans is just done, i got it from this high school kid, did a lot of power breaking and stupid **** like that, he said that he had never serviced the trans, what ever i got it for only $500 bucks, so if rebuilding is in my agenda, what should i use, my friend used the TCI kit S3, what else is there???
Old 09-30-2008, 10:40 PM
1sick68's Avatar
no it does not, just into 1 2 3, but not into OD.....
Old 09-30-2008, 10:48 PM
Yeah, sounds like it's time for a rebuild, but I don't know a whole lot about autos i'm sure others will chime in
Old 10-01-2008, 08:57 PM
93lt1M6z's Avatar
i second it. need to replace or rebuild. either way sounds like the trans is toast. should still get it scanned
Old 10-01-2008, 09:23 PM
RoAdRaGe912's Avatar
Lots of people quick to jump to an expensive conclusion when he hasn't mentioned anything but a single symptom.
You said it hangs up in first sometimes as well? At part throttle (normal driving) what kind of rpms are you seeing before shifts into 2nd and 3rd? Does it have any problems idling in Drive, like at a red light? Does it have problems shifting at WOT?
Old 10-01-2008, 09:51 PM
sweetbmxrider's Avatar
have you checked the tranny fluid? check engine light wouldn't kick on for the trans i think. what condition does the light come on? could be something simple like an egr. just have a shop scan it though. too hard to diagnose the check engine light over the internet with out a code.
Old 10-01-2008, 10:35 PM
I8ASaleen's Avatar
Get it scanned.
Then come ask SES light questions.
Quick Reply: service engine soon????
