need help locating a part
im assuming you meant knock module and i believe its inside the pcm. open her up and switch them out. try to verify that before you start but im pretty sure about that one.
Pop your hood, go to the passenger side, and right between the firewall and the fender, the computer will sit. Unbolt it from the fender, its a 10mm bolt, then gently pull up the computer, flip it over and there will be a cover, held in place by 2 bolts. Those bolts are T20s, unbolt them, remove the cover and you will find your knock module. Hope this helps. Also make sure that you disconnect your batter before you start.
