Dart 205/ F13/ FAST 90/90 - Dyno Results
Old 10-01-2008, 06:36 AM
Bandit LS1's Avatar
Default Dart 205/ F13/ FAST 90/90 - Dyno Results
Picking my car up today from Eastside Performance in CT, but the results are:
423 HP / 397 ft-lbs Torque on a DynoJet
I am happy with the results and they seem reasonable since I am running a Ford 9” with 4.11’s and a Catted Y-pipe. What do you guys think?
Mods are in my sig, with the exception of the 85mm MAF. My tuner recommended using the stock MAF instead.
Old 10-01-2008, 07:38 AM
AINT SKEERED's Avatar
Looks good, may not be high numbers but that cam should have a great powerband. post a graph when you can.
Old 10-01-2008, 08:24 AM
LSX Mechanic
Damian's Avatar
You've got some power on the table in the heads. I've installed 2 sets of Darts and they didn't make dick for power.
Without the heavy drivetrain you'd be in the 445 range so that isn't too bad.
Old 10-01-2008, 06:40 PM
SIC LSX's Avatar
darts are not worth it out of the box
Old 10-02-2008, 06:53 AM
Bandit LS1's Avatar
Here's the graph:
Attached Thumbnails Dart 205/ F13/ FAST 90/90 - Dyno Results-ws6-dyno.jpg
Old 10-02-2008, 07:55 AM
like I said , good power where it counts. That cam has good bottom end and holds on.
If the heads ever come off for any reason, get some work done for an awsome combo. You should not regret buying the heads though, Not everyone makes 500 rwhp. Solid mid 11's car.
Old 10-02-2008, 08:04 AM
Sigforty's Avatar
Those are very good numbers. It looks like they are the actual HP numbers for that day. You need to find out what the weather data was, and see if you can get some SAE corrected numbers.
Old 10-02-2008, 08:36 AM
PewterScreaminMach's Avatar
Who tuned the car now that Alfred's not there anymore? Was it Kenny?
I personally am not seeing how his Dart heads are making bad power considering that heavy, geared rear and the cats he's running through. Looks like decent numbers to me for out of the box heads that cost $1,200. I would be happy with that. Not everyone has the money for $2,500 heads.
I still don't understand Eastside's tendency to talk everyone out of putting a bigger MAF on the car. I know they say they didn't see big improvements on their cars, but I've seen mixed results on here and some very decent gains. Did you already have the 85mm and they talked you into putting the stocker back on? I just don't get it.
And I'd definitely like to see some SAE numbers, as well. I guess if your numbers go down from that then the Dart argument above might make sense but in this weather we've been having, I can't see how they'll change too much.
Old 10-03-2008, 08:20 PM
Checkmate's Avatar
How about some track numbers.
Old 10-03-2008, 08:35 PM
Redlinez's Avatar
Plenty of 460 rwhp cars running mid 11's too. Yea, you need SAE corrected to be able to compare to others. Good numbers either way. I made 413/389 with the 225's, but I have a LS6 intake and 4.10 geared 10 bolt.
Old 10-03-2008, 09:05 PM
12secSS's Avatar
Good numbers. I have no idea why your tuner would recommend the stock MAF, versus the 85mm one. It defeats the purpose of going to a 90/90 setup.
Old 10-03-2008, 09:24 PM
Martin HD-28's Avatar
My tuner had me do the same thing. I had to take off my granatelli and put the stock back on.
Old 10-04-2008, 04:05 AM
F8L_LS1's Avatar
exactly.
imo, if your tuner cant tune with a 85mm...it might be time to look for a new tuner.
Old 10-04-2008, 07:33 AM
tillery's Avatar
Seriously guys, why do you all think that a aftermarket MAF of the 85 will give up more power? It still going to max out at the same power level and you can use the money saved on other speed goodies.Now if we had a say 40mm MAF, then we would need a bigger opening. Once you max you stocker, go SD. Or get real fancy and run two MAFs(in parrallel not series). A engine will pull what air it needs thru the stocker. But then its your money. Take your car to the track and see the results there.
Old 10-12-2008, 08:06 AM
Bandit LS1's Avatar
I definitely didn’t want to remove the 85mm MAF and Lid since I bought it to complement the FAST 90/90 setup. Don’t get me wrong, Eastside did great work on the car. It just surprised me when they asked that I run the stocker, especially when I read plenty of posts with people running the bigger MAFs with zero problems.
And to answer PewterScreaminMach’s question – Yes, I believe Kenny did do the tuning.
Old 10-12-2008, 08:55 AM
LS1Tech Sponsor
Slowhawk's Avatar
I've seen alot of screwed up 85mm MAF's= expecially the Ganatellis.The stock descreened MAF flows very well,port/knife edge it and it flows extremely well.
Most tuners do not want to tune in a 85mm MAF setup because it takes more time.Also requires to be street tuned or use a load dyno.From what I've heard ESP will only tune the car on there non-load dyno,not hit the street with it.This is why they want the stock MAF.
Old 10-12-2008, 09:31 AM
CraZee ZO6's Avatar
how big is the stock maf on the zo6? anyone know.
I am doing a ported 92 to 100mm and a rev extreme 100mm tb and was wondering if I should pick up the LME 100mm MAF to get a full 100mm setup.
Please let me know what you think SLOHAWK, very much appreciated.
Should I run the stock maf or the 100mm lingenfelter unit for my setup.
Old 10-12-2008, 09:45 AM
Sigforty's Avatar
The stock Z06 maf is 85 mm. There is no need to upgrade it unless you are putting down around 600 rwhp.
Old 10-12-2008, 10:04 AM
sprydncamd ta's Avatar
i have the same setup minus the fast intake and put down 444.4 through my 9 inch
Old 10-12-2008, 11:29 AM
Bandit LS1's Avatar
Interesting....what kind of dyno?
Quick Reply: Dart 205/ F13/ FAST 90/90 - Dyno Results
