Pic Request-Strano Springs w/ aftermarket wheels(18's-19s)
I allready searched for hours, so please dont tell me to search again. If anyone has these springs along with some 18s-19's Id really appreciate if you would post some pics!
Thanks.
Thanks.
A lil off topic guys (don't mean to thread hijack) but how much groud clearance did you guys lose with both the 18" wheels and stranos combined? I would assume .75" - but there's nothing like checking the actual application.
So out back i guess i probably lost about.... 0.7" of ground clearance???
LS1TECH Sponsor
Those are some great pics guys... Mind if I use them on my site or refer folks to them from time to time?
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
PLEASE remember that there is no exact ride height for all cars. They all start differently and can end up differently. But if you take a look at the line that runs down the side of the car vs. the top of the tire, you'll find his pics are very much what most cars end up like.
Be aware that there cars out there that have larger than stock rear axles. Cars that have 9" and 12-bolt rears have 3" axle tubes. The 10-bolt uses 2.6" axle tubes. The springs sit atop the axle, and that difference can account for up to a 1/4" difference in height. When you consider that the steel used for the spring mounts on the axle might also be thicker, cars with aftermarket rears should not be used as a guide, unless you also have the same axle.
In short, read the sigs of those that post pics and make sure you are looking at a car that's like yours.
__________________
I like the stance your car has wan2run, the rear doesnt sit high like most strano springs. For example, the red T/A above. I realize different rear ends make for a different ride height, thanks
