Solenoid ground help
Ok I'm installing my nitrous again this time I do not have coil packs over the heads, have no egr, air system, or cpu harness and want to do it cleaner this time without really using wire loom. So far i cleanly did the fuel side ground, and the other wire for the fuel and nitrous solenoid and the one side of the purge solenoid. My issue is where to ground the nitrous and purge solenoid. Last time i ran it over to the shock tower but dont want to cross the gap. The nitrous line is going to be in the fender coming out by the battery and plumbed up to the solenoid.
Current engine bay pic for reference
previous nitrous set up
What do you think of putting one of the egr bracket bolts back in and grounding it there?
Should I plumb it up to one of the ground bolts on the front support brackets?
What other ideas?
What other ideas?
8 second mod
i run my grounds to the back of the heads, there are 4 holes in the back of the head, just like the front, i go to one of those. its a tight squeeze and not easy to get to, but it hides the wires better then anything else, its under the cowl and looks 100% mint.
