power with this cam?
Old 10-02-2008, 04:44 AM
Pete walsh's Avatar
Default power with this cam?
Intake Duration: 233
Exhaust Duration: 276
Valve Lift (1.8 Rocker):630
Lobe Seperation (deg): 107
in a ls7?
and will std springs be ok or will i need uprated ones?
cheers
Old 10-02-2008, 09:19 AM
Pete walsh's Avatar
im guessin its still a bit early
Old 10-02-2008, 09:33 AM
KONG's Avatar
That is a Katech grind. You should talk to those guys about the particulars. Hope I helped.
Old 10-02-2008, 09:36 AM
Pete walsh's Avatar
oh i got it from GMPP. lol
Old 10-02-2008, 10:41 AM
Stang's Bane's Avatar
It should make in excess of 625 at the crank.
yes you will need better springs.
Old 10-02-2008, 10:51 AM
Bink's Avatar
It's the Stage III GMMP cam.
Here's a link, check out 3rd page for specs and dyno.
http://www.hotrod.com/techarticles/e...est/index.html
Old 10-03-2008, 07:57 AM
Pete walsh's Avatar
For the stage 3 cam it says I need different valve spring retainers.
Any idea where from or if GMPP sell them?
If so any Part numbers?
cheers
Old 10-03-2008, 11:23 AM
Bink's Avatar
cheers
Probably the Katech LS7 retainers.....I think they have unique retainers. Call Jason at Katech.....good guy.
Old 10-03-2008, 04:52 PM
Pete walsh's Avatar
any idea if the gmpp ls7 performance c/h's assembly retainers will work?
[exscuse for more power]
Old 10-07-2008, 03:41 AM
Pete walsh's Avatar
any one?
Old 10-07-2008, 07:59 AM
Pete walsh's Avatar
any one in?
Quick Reply: power with this cam?
